Dear All,
I'm trying to put a simple table to Global, just to test it. I've seen an example and I based my test on it but it return an error that I don't understand.
Here's is the code:
%% properties
%% globals
local tableau = {id1=91,id2=96}
fibaro:setGlobal("mon_tableau", json.encode(tableau))
fibaro:sleep(2000)
local mon_tableau = fibaro:getGlobal("mon_tableau");
local devices = json.decode(mon_tableau);
fibaro:debug(devices.id1);
if ((fibaro:getValue(devices.id1,"value"))=="1")
then
fibaro:call(devices.id1,"turnOff")
else
fibaro:call(devices.id1,"turnOn")
Here is what it returns:
[ERROR] 12:48:26: line 12: Expected value but found T_END at character 1
Line 12 is: local devices = json.decode(mon_tableau);
Any Idea what's wrong with it?
Thank you in advance!
Tibus31, damaged or null json
    Hi Andre,
    Any Idea how could it be while you see it's not null and shouldn't be damaged as very small and easy table...
    add checking errorCode and status
