www.qubino.com
Look nicer than fibaro modules and have more features and smaller
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> and probably allowed to be sold in every country
and the shutter supports 24V, nice!
The Fibaro modules are 42x37x17 and these Qubinos seem to be 41.8x36.8x16.9 and some 41.8x36.8x15.4 so I doubt that the 0.2 or 0.1/1.6 millimeters will make a huge difference
    yes but judging by some comments on here these are less likely to melt?
    Oh, I haven't seen any comments to that effect yet but I'd pretty amazed to see any reliable info with statiatics to back it up.
    Plus they have wire terminals for additional sensors. However there is not a single mention of an address on the site other than that they manufacture in the EU, don't like that.
    I have tested few qubino modules and there are few things to work on also...
    About the cool look - I dont see that this half cut design is good thing, dimmer has one element exposed and when you are not enough careful you can damage dimmer while installing.
    Dimmers seems to have strange startup flash - it doesnt start smootlhy, it first makes small flash and then starts to work normally. I tested it with LED and otherwize it was OK.
    With fibaro HC2, 2xrelay do not operate normally, relays seems to be connected - one is working normally but the other one affects first one too (from hc2 interface). Also there are much less parameters and options..
    Lets see what these will become, but this is sure - competition is good and makes everybody work harder. (Lets hope that it doesnt mean to use cheaper details)...
    3kw relay seems to work good, like fibaro's. No noticable difference, exept alittle higher price tag.
    Lauri.
    Pros and Cons for Qubino vs Fibaro?
    Anyone can come up with the comparisons?
    I guess that since the dimming circuit is based on a mosfet circuit, it will be working on a PWM principle, so it will be a trailing edge dimmer and therefore not be prone to over heating. But the lack of documentation makes it difficult to ascertain whether this be true.
    I also have not found any technical information regarding if it is leading or trailing edge dimmer. The official specs
    does not say anything about that. Nevertheless since trailing-edge dimmers usually uses MOSFET or IGBT switch rather than a TRIAC and coil (according to what I found) - there is a hope that it is a safer modern trailing edge dimmer. The possiblity of connecting DS18B20 is another great feature! The disadvantage of this dimmer is 3 wire connection.
    I am anyway waiting the delivery of Qubino dimmer and Qubino 2 relay switch to play with it.
    As for Fibaro dimmer - another dissapointment happened yesterday. My FGD211 dimmer stopped to function. It did not melt, but it just stopped to communicate with ZWave controller. It worked stable about half a year. My inspection showed that Megaman LED works fine, the problem is in dimmer.
    There is also another alternative which can also be installed without a neutral - BeNext dimmer
    No ideas what type of dimmer it is. What I can see though it has overload protection.
    You got me interested... What kind of 24V gear would you hook it up to?
    Regarding the relays, I wonder whether these can handle power supplies, chargers &c. (As discussed in other threads.)
    24V blind, I now use a double relay.
    I have tested Qubino dimmer module (in eedomus) and have very positive emotions in general.
    Advantages:
    - Very smooth dimming
    - 3 channels (load, binary input, binary input)
    - Possibility to connect DS18B20 (this was not tested)
    - No need to install bypass with LED lamps
    - Device has no noise at all!
    Disadvantages:
    - There is no "scene functionality" as in Fibaro modules, channels can be used just used in the association
    - 3 wired connection (with neutral). Moreover it uses a switch on Neutral which is not approved in Sweden (if I understood this correctly from one of the forum members).
    - Energy meter works in a bit strange way - the idle consumption is 0.6W, but it shows 250W on 10W LED lamp load.
    /emoticons/default_icon_eek.gif" alt=":shock:" />
    For those who are curious. I have also tested this one - nothing interesting, has one switch, uses no neutral. BeNext support told me that it is a TRIAC leading edge dimmer.
    [ Added: 2014-07-21, 17:41 ]
    Not exactly so, there are 2 separate devices corresponding to channel 2 and 3 - so these channels can also be used via rules.
    we have tested with Fibaro, Vera, and Zipabox
    with Vera and zipabox is OK, with Fibaro not is perfectly
    Dimmer:
    In eedomus it works more less OK. The main problem is in wrong energy consumption.
    1 relay
    [ Added: 2014-07-27, 09:30 ]
    2 relay
    [ Added: 2014-07-27, 09:35 ]
    shutter
    I have ordered a dimmer module this morning, it should be in tomorrow.
    Hope this dimmer solves my LED problems; I'll post my findings when I have played around with it.
    Edit: the module was not functioning correctly, I’ll send it back to the shop for replacement. I have a friend who tested a module with Domoticz, he was pleased with the results... That’s it for now when I have the new module and tested it I’ll post my findings
    anyone else can give feedback on qubino modules on Fibaro HC2 ?
    Do they support well led diming ?
    Are all options available trought the HC2 interface ?
    Are scene activation availables ?
    next week I will test them with the new HC2 4.017 BETA
    tested the dimmer with 4.017 and is not working great.
    Wil work with 3.590
    Dimming works.
    Setting parameters and association works.
    2nd input is seen as motion sensor.
    Later FW versions only dimming works, not possible to change parameters and or associations.
    Have a HC2 running on 3.590 4.017 and 3.907
    No problem with Philips 230V led 4W dimming over complete range without flickering or humming.
    thanks for this feedback !
    what about scene activation please ?
