My Fibaro switch has suddenly 3 devices instead of two.
3.591
reconfigure this device.
    Already done, still there.
    Are you able to control all the switches? or 2 of the device is the same switch? are you using 1x3kw or 2x1.5kw? using fibaro hc2 or vera?
    Did you deleted your device by entering learning mode and then adding it again?
    Yes it now works again. Shouldn't happen though.
