Turn virtual device input into system stuff?
Hello all,
Im grabbing things like current power usage, solar power generated and so on from our domoticz device and sending it to a virtual device in Fibaro. However, Fibaro ofcourse doesnt recognise these things so you can see it back under 'Consumption' or other fibaro recognised things. Is there a way to tell Fibaro it should be used or thrown into Consumption or anything else?
7 answers to this question
Hello all,
Currently: No
In the mythical 4.x if You manage to write a plugin for it:Maybe, there are rumors at least.
tcviper, such a thing can not be done with virtual device.
Will we be able do this with virtual devices is v4? Or at least set the device type for the virtual device to tell it that it's a light or something else so we can add it to the ALL OFF/ALL ON command.
I would like to know the answer to this too.
In v4 will we be able to make plugins or virtual devices that appear in the UI as native device types? I.e. a Philips Hue plugin/virtual device that appears within the "Lights" section on the iOS apps?
Or temperature sensors...
This is easy to implement. Vera supports this.
The question is if they want us to use our own sensors.
Please do.
Dear users, your suggestions are very important to us and we will consider this functionality.
