Wake up Fibaro smoke detector (manually)
Guest Lode
I changed some parameters of the fibaro smoke detector
For testing i tried to wake up the device by triple click the B-button (as described in the manual) but it doesn't wake up
/emoticons/default_icon_neutral.gif" alt=":-|" />
Remove power/battery and try again?
the safety device is not looking to safe
Hi, to wake up the Fibaro smoke detector should be the same as waking up a door/window sensor.
how do I wake up a door/window sensor?
press 3 times like when you add/removing device or wait 4000s
button "configure to factory settings" get all configuration device that way it looking like new adding process w/o removing with that same nodeid and id
Lode, if standard procedure (as described above) do not work, please reset your smoke sensor and try adding it again.
