Hi everyone,
reading through the SQ-Blaster API information I gave it a go to create a virtual device and integrate my IR machines into the fibaro.
Steps:
-Get your sq blaster XML files from box.net
-Look for device numbers in PackageDevices.xml
-Also note the ir-channel and repeat number
-Open the corresponding devXXXXXXX.xml
-look for the command name you want and copy the ir_command
Create a global variable SqIP with the IP of the Sq-blaster
Now create a virtual device and add this code to a button:
Virtual device code:
Hi fellow SQ Blaster user,
You are actually using lua code under your virtual device, am I right?
I guess your codes are working just fine?
I'm using string code. Please feel free to take a look
