Compatibility with 'Universal Relay switch 2.5Kw wiDom'
Dear Fibaro Team
can you tell me if "Universal Relay switch 2.5Kw wiDom" is compatible with your system HC2?
Thank you
13 answers to this question
Did they mentioned their product is z-waved?
    WiDom Universal Relay Switch is a Z-Wave certified “in wall device”.
    Radio Frequency 868.4 MHz
    Then it should be compatible. If it's not, please inform us
    I think that Scucciari want to know the compatibility of that device with HC2 before buying the product ......
    Since Scucciari mentioned that it's a Z-Wave certified “in wall device”.
    Radio Frequency 868.4 MHz.
    It should be compatible. If not, please update fibaro so that they can update the list of compatible products with fibaro.
    That's the problem. It should be ...... (some people prefer to know if a device is compatiibile before spent money !!!!!!)
    BTW : There is a public database of zwave device compatibile with HC2 / HCL ?
    ..thank you candrea77, you have hit the concept.
    I was hoping for a professional response by Fibaro.
    Excuse for my bad English
    In that case, why not get the fibaro relay module? That will definitely be compatible.
    PS: I've seen the compatibility table of zwave product with hc2 but it don't seem to be updated with the vast introduction of new zwave devices.
    "Universal Relay switch 2.5Kw wiDom" it's not on the official Fibaro list. However, it should be compatible as long as it is Z-wave device, at least its basic functions (e.g. switches, power metering).
    Il relè widom è perfettamente compatibile con HC2, HCLite, Zipabox e Vera, tutti i parametri riportati a manuale possono essere sfruttati con tutti i controller .... testato in maniera diretta
    The relay widom is perfectly compatible with HC2, HCLite, Zipabox and Vera, all of the parameters listed in the manual can be exploited with all controllers tested in a direct way ....
    [ Added: 2014-07-26, 18:10 ]
    [ Added: 2014-07-26, 18:33 ]
    Thank you antamaga, for the update. Hope Fibaro update this module into their compatible list.
    and WiDom Universal Roller Shutter
    are fully compatible with Fibaro System.
    We recently updated our Web Site including compatibilities information and several scenarios you can implement using WiDom modules with Fibaro.
    For any further information and any help just write us an email
