Support for Germany speakers Fibaro User, i need help?
OK, i hope for help here. We are 5 Users (friends) of Fibaro.
I will Translate the difficult think with google Translator.
I have follow problem:
The Scene i wish was follow:
1.) After the Sun goes up the Roller goes to open
2.) the Problem is my door Sensor
3.) I have one Door Sensor. When the Sensor is closed in the evening (after the sun goes down) the Rollo goes down.
4.) Is the Door Sensor open, then the Rollo does not closed (than i am sitting in the garden :- )
5.) After i closed the door than can closed the rollo
door sensor is FGK-101 from Fibaro
My Problem is when the Rollo is open and i open the door than goes the rollo up to closes
I closed the door! The Rollo goes to open ?????
1
2
%% autostart
3
%% properties
4
58 value
5
%% globals
6
7
8
local sourceTrigger = fibaro:getSourceTrigger();
9
if (sourceTrigger["type"] == "autostart") then
10
while true do
11
12
13
14
if (
15
( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and os.date("%H:%M", os.time()-45*60) == fibaro:getValue(1, "sunsetHour")) )
16
and
17
( tonumber(fibaro:getValue(58, "value")) == 0 )
18
19
then
20
fibaro:call(31, "close");
21
fibaro:call(31, "setValue2", "0");
22
can you not set a GLOBAL VARIABLE?
ISOPEN
ISCLOSED
so when door is open check rollo ISOPEN or ISCLOSED?
set the variable by block scene
when rollo open then set variable ISOPEN
or
scene 2
when rollo closed then set variable ISCLOSED
    Sorry i am so new, i worked only with the color blocks an the are no way to choose this one!
    Here is my scene. It works great.
    12 is roller shutter 2 FGRM222
    39 is FGK101 Door/Window Sensor
    Please what is here wrong?
    I will that the Rollo open after 6.00 in the morning or after sun goes up!
    Momently open the Rollo in the evening too....... but i think is is every time after the sun goes up.....
    I have one motion sensor and the roller shutter.....
    Please give it some features to say, open when motion only at daytime or so?
    %% autostart
    %% properties
    59 value
    %% globals
    while true do
    if (
    ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and os.date("%H:%M", os.time()-30*60) == fibaro:getValue(1, "sunsetHour")) )
    and
    ( tonumber(fibaro:getValue(59, "value")) == 0 )
    then
    fibaro:call(33, "close");
    fibaro:call(33, "setValue2", "0");
    fibaro:sleep(60*1000);
    else
    if (
    ( (currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) )
    and
    or
    then
    Here is how it works in my house.
