I have a 2x1,5 relay, and am trying to connect a circuit lamps.
At first I cared about was the neutral, but already made ​​the transition to be neutral in the required location.
Now my problem is I want to connect two lighting circuits, each in a output, but one of them is in parallel (with two 3 way), I can not find to do it. The other circuit would be a single key, I think it is easier.
Thanks in advance.
Like you would a normal 3-way, just replace the load with the input in the fibaro 2x1,5?
It should work.
    Ok, thanks a lot for both.
