stevenvd 51
How bad would it be if a module would send out a signal every 6 - 8 seconds?
I was thinking of adding a small pic microprocessor in a keyfob. The pic would just trigger the keyfob every time.
If you have a scene running to check constantly that the keyfob is active you are at home.
When you are away the scene will just stop receiving triggers.
When you walk to your house again and it receives a trigger, it could for instance unlock the door.
Any ideas on this?
[ Added: 2014-07-09, 12:04 ]
Oke, easier: Take a Fibaro motion sensor, disable the motion sensor, disable the lux. Set the vibration reset to a short interval. Take the cover off the device, replace the battery with a CR3032 or so and place it in a very small casing (or tape)
This works like a charm! Now I just have to find a casing for it...
It triggers a scene when you have the keys with you. without doing anything.
My away scene checks next to all the motion sensors if this device has not been breached for x minutes and that means I am away.
No need for an active RFID now:D (just a casing... Ideas?)
mhhh, maybe just print it!
[ Added: 2014-07-09, 13:09 ]
Fibaro: THIS is your next product!
It is to simple. And you already have it. The motion sensors circuit board is round, small, build for 3 volts, and has 3 inputs.
Use 2 for buttons, and one for the vibration sending to the HC2. Just put it in a keyfob casing and your product is finished! What more do you want? Relase next month?
/emoticons/default_biggrin.png" alt=":D" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />8 answers to this question
