Anyone knows how to wire the FGRM222 without involving a physical switch in the process?
I have 3 wires coming from the wall and 4 wires coming from the blinds.
Many thanks!
Use schematic from
but don't connect anything to s1 or s2. If you are not sure about wiring ask an electrician for advice.
    Thank you! It is not working but it is not the fault of the fibaro device. I suspect there is something with the blinds... I will check...
    I just want to say that is fixed. The issue was that i was not wiring correctly. The two null wires (the one going to the motor and the one coming from the power outlet) had to be united and put together in the null slot.
