thijs 1
I have a Koubachi and retrieving the data trough a php script, as mentioned on
(Thanks guys!!!)However, when the temp light and moist values are set in the Global Variable panel the symbols (°C, lx and %) are set as well. This causes trouble when using it in a scene as the variables are not seen as numbers and that is necessary as I want to use the moist value as a trigger.
I think this can be solved in 2 ways, but either way I don't know how. Who can help?
1) Try to set the values without the symbols. In this case I have to extract the pure values out of the json file through the php script. I have the following LUA code in my virtual device. How to adjust?
-- NAME: koubachi-fibaro
-- Author: Zebk
-- Date: 14/07/2013
-- Comment: Collecter les donnees d'un capteur Koubachi
HC2 = Net.FHttp("")
response = HC2:GET("/koubachi/Koubachi.php")
result = json.decode(response)
local light = result.device.recent_light_reading_value
local temp = result.device.recent_temperature_reading_value
local moisture = result.device.recent_soilmoisture_reading_value
i = 1
while i <= 360 do
fibaro:setGlobal("Koubachi_light",light)
fibaro:setGlobal("Koubachi_temp", result.device.recent_temperature_reading_value)
fibaro:setGlobal("Koubachi_moist", result.device.recent_soilmoisture_reading_value)
-- assign local variable to virtual device label
fibaro:call(177,"setProperty","ui.Label1.value",moisture)
fibaro:call(177,"setProperty","ui.Label2.value",temp)
fibaro:call(177,"setProperty","ui.Label3.value",light)
fibaro:log("Light: "..light.." - Temp: "..temp.." - Hum:"..moisture.."")
fibaro:sleep(1000);
i = i + 1
2) Adjusting the LUA code of the scene so that it can read the symbols for triggering below a certain value. First I used the scripting block without success. I have translated it to LUA code
(see below the first part of the code). If I have to do something here I think it should be where the trigger value is mentiod 'tonumber ( "75" ) )'. But how to adjust?
%% properties
%% globals
Koubachi_moist
local sourceTrigger = fibaro:getSourceTrigger();
if (sourceTrigger["type"] == "autostart") then
while true do
if (
( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "14:43") )
and
( tonumber(fibaro:getGlobalValue("Koubachi_moist")) < tonumber( "75" ) )
then[/color]
Who can help me solving this?
