I'm looking for a easy to use, o -course with hc2 and hcl, scene selector panel. Like you see in KNX or DALI installations, 230v or battery powered...
I've found some US z-wave panels, but no use for 110v or US frequency....
please help.....
Take a look at Niko. 24 volt. (4 voudige potentiaalvrije drukknop) works well with the robe module.
Do you need just switch or scene activation module as well? You can use D/W sensors (battery device) or UBS (needs power supply) as scene activation device, attached to ordinary wall switch.
    What i need are in the best case 6-8 buttons, where i can assign a scene to. 4 buttons are not enough, i need to turn of the lights also and because of that i have only 3 scene buttons left.
    The lights we use, use 2 channel 1-10v controlled led strings, one cold and one warm white string. Whit this configuration we can make all the colors from the daylight spectrum.
    When we sell this to our customers, we want to make it easy... Eg push a button and you get the active light setting....
    • 2 years later...
    Hi. What did you use with the Niko button? Was it the Fibaro rgb module? Do you get feedback on the led?
