Just received the following advice from Sonos:
In the coming months, we will release a software update to all Sonos customers with new features for the system. From this point on, iOS4 and 5 devices, including the first generation iPad, iPhone 3G, and second and third generation iPod touch, will no longer function as Sonos controllers.
What it means for you:
When you initiate this update when prompted on any device in your household, your speakers will no longer be able to connect with the devices above. This update is irreversible.
I wonder if this upgrade may effect the current method of Fibaro control, and/or the coming 4.X upgrade?
/emoticons/default_icon_eek.gif" alt=":shock:" />
Be alert but not alarmed!!
mclass
mclass, our system does not use direct control via iOS, it communicates directly with devices, using SONOS's API. So there is no reason to concerns
/emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
