Lua code opening door + motiondetector does not trigger lamp
Hi Folks!
I try to learn lua code from scratch. not just copy & past... and i need some basic help
Why does not the lamp (id28) flash , when "door1" and "ir" becomes ones.
It feels like the script does not start automatically, but then I press the "start" it works if "door1" and "ir" are ones.
I am probably missing something, a start command?? (Active scene is checked)
my code:
%% autostart
%% properties
20 ,60 value
%% globals
local ir
local door1
door1 = fibaro:getValue(60, 'value')
ir = fibaro:getValue(20, 'value')
fibaro:debug('Doorsensor is = ' .. door1)
fibaro:debug('IR-sensor is = ' .. ir)
if (door1== "1") and (ir== "1") then
fibaro:call(28, "turnOn");
fibaro:sleep(2000);
fibaro:call(28, "turnOff");
try like that
    piotr.janiak: Yes THX
    Think i need a break
