Hi All,
Just, on advice of others, thought I would change reporting to different values e.g param 64 to 1800 from 900.
However whatever I change, when I save it, I go back in and see that it's still the same...it wont change for some reason?!
Any ideas?
KR, Dave
Hallo,
change the values and then press 3times the B-button.
I had the same problem.
jan
    S'alright I think I worked it out, though thanks for suggestion, I think it was just taking it's time to reconfigure the device that's all.
    KR, Dave
    This is not a problem, it's normal behaviour for battery powered z-wave devices.
    When you made parameter changes always wait for the wake-up to see the changes, or even better, give a wake-up manually (triple click).
    in my case, the configuration will be only done successful if the motion sensor are next to the HC2. If it to far away and the signal will be routed, it seems to be not working.
