hi
i have a scene that turns the lights on when a motion is detected. however i want to keep manual control when i trigger my bi-stable switch.
i want to set parameter 3 to 3 to activate manual control for both relay. when i make the change, it keeps it's configuration to 1. so manual control works only for one swith
anyone had this problem/bug?
is there any other way to keep manual control on both relays ?
thank you
maczouz, parameter 3 can only gets values "0" and "1". And it is not responsible for controlling outputs. can you describe exactly what do you try to achieve?
    hello,
    i have a motion sensor that turns on the light when it detects a motion( scene) during a specified time ( 30 sec). it works fine. however, if i try to turn of the light with the wall trigger when its detects the motion. it dosen't work ( the light go back to on for 30 seconds)
    basically i wan't that manual control overides the scene.
    plus , it is specified in the user manual that parameter 3 can get value 0 1 2 or 3.
    any clue?
    maczouz, what version of firmware do you have on your switch? I was referring to parameters in latest one and it only gets values 0 and 1. Anyway, auto-off function will not help here. I see two way to do it:
    1. You can install normal, bi-stable switch BEHIND relay switch. That way if wall switch is off, the light will be off no matter what, but you will not be able to turn light on with wall switch and state of relay switch in the interface can differ from actual state of light.
    2. Using UBS module connected to bi-stable switch and when MS is turning the light on, just check state of its inputs as additional condition.
    hello
    switch version :
    FGS221 Switch 2x1,5kW EU
    Version:2.1
    what do you mean by UBS module?
    maczouz, Universal Binary Sensor
