Pushover notifications
Guest Lode
I'm trying to use pushover for my alarmnotifications.
I placed this string in a virtual device :
Token and user keys double checked and they are ok.
Ip address : 184.154.74.158
Port : 80
Everything seems to be ok but i don't receive any notifications.
On the website of Pushover i send some testnotifications and those i received.
18 answers to this question
Strange. I have pushover running perfectly.
HC2 3.591 beta
Screenshot attached.
Guest Lode
    It's ok now....
    There was a space somewhere between the string,
    Don't know if that caused any problems but now it's running perfect !
    Just in case anyone runs into a similar blonde moment like I did - there is no space/new line between messages.json and token=xxxxxx
    It just looks like there is in the text output and picture *sigh*
    Guest Lode
    Correct ! That caused my problem
    By the way, any idea how to send pushover notifications from LUA?
    Found some info here
    But understand nothing. Please help
    You send pushes as follows:
    fibaro:call(phoneID, "sendPush", "msg", "msg")
    j.nowacki, Thank you, it is clear. But I want to use external service Pushover.net and cannot understand how to make it working in LUA.
    Now I use it like a virtual device and it works great.
    Please help
    @amj
    Look here:
    HeroS, If you look two posts before you will find that I know about this link.
    The problem is that i cannot understand how to implement it.
    Should I just include this code to a script:
    [ Added: 2014-08-29, 07:14 ]
    Any news on that? Please )
    Just received an email saying that I'm using an old IP address for api.pushover.net.
    Please note that it will be not working soon unless you update IP address of a virtual device to 108.59.13.232
    Adding to this thread
    According to the blog post in this section i thought that they have stopped using the IP and is forcing the use of HTTPS
    Note: This change does not affect end users of Pushover. For most developers and others using our API, no change is required on your part unless you have hard-coded our IP address.
    From my understanding it may work but they will change the IP in the future without notice. Can anybody confirm this?
    Until you listen to your customers they will use alternatives for push messages.
    (No priorities, serial as a title,...)
    That is the LUA code for fibaro push notification isn't it? I want to use pushover that way I can configure one message to all my devices and I can program priority on the message. If the fire alarm goes off and my phone is on silent the phone will still make an alarm sound. If I accept the alarm on one device it will be accepted for all my devices. I also have a log of all notifications. I can also program tasker to handle scenarios based on pushover notifications. I control my harmony remote control that way. Fibaro push service can not make that happen.
    pathduck, agree, fibaro notifications are primitive
    Is it possible to use lua code (only) to push msgs to pushover? I'm getting errors at the require lines.. Don't know if the fibaro implementation lets you include anything at all..
    If there is anybody who has pushover working in fibaro with lua script I would love to see the complete code here...
    [ Added: 2014-12-06, 08:26 ]
    Not working in 4.021 Beta
    While this is not working I would very much like to be able to use pushover.
    Can you PLEASE help us out how we can get this to work in lua ?
    I solve it temporally by making a new user in access control panel with pushover email such as [email protected]
    [/code]
    I for one would sure like to be able to use pushover directly or via lua scripting!
    Please enable it fibaro!
    I have managed to create a Virtual Device which send a (predefined) message to my iPhone.
    So in a scene I can "push" that Virtual Device and let me send that message.
    But how can I include e.g. a LUA-value of a Door/Window-Sensor? I have a script checking each Window-Sensor if it is open and send a push message like "Window xyz is still open" - how can I do this? I cannot create a VD for every Sensor...
    Thx
