Quikdav 15
Hi all
I need some advices regarding a LUA script I would like to write.
I would like to monitor an air sensor using a virtual device and then select the icon depending on the quality of the air. 2 solutions :
- I use the main loop of the virtual device but the main loop is executed each 3 seconds so if I need global variables (to summarize value, first one, last one, etc), I have to create them into the panel Variables and load them each time the main loop is executed (I choose this one but not very conveniente with global variable)
- I use a scene with an infinite loop so I can declare and manage variables only in my scene abd I can change the icon of the virtual device
I don't know what is the best practice in term of performance and ressource
Thanks a lot for your advices
