HTTP request HCL
I am aware that HCL doesn't support LUA. But, is there a way to send simple HTTP command from HCL to other IP based system using virtual device? example like below command
address/command/?cmd=temp%200058
13 answers to this question
    Got it working..
    yes in virtual device use search on forum with "virtual device GET"
    Tried searching lot, could not get proper information. All i found is LUA based. Can you explain how i can do this without LUA
    Ahmed,
    what type of IP based system do You want to use?
    its a simple IP based relay.
    uses simple http control like,
    XXX/command/?cmd=stop
    XXX/command/?cmd=start
    this command perfectly works over webpage. To test from HCL, i also added this same command in one PTZ control of IP camera. Even it works when i press that button. Just not able to configure in virtual device
    Have a look at this:
    I made a working virtual device. Just change the address and you should be good.
    Ahmed,
    simple http commands won't work in virtual device buttons without lua
    Try creating a virtual device with ip adress of Your device.
    Then create button and place there command:
    GET /command/?cmd=stop
    HTTP/1.10x0D0x0A0x0D0x0A
    It is also important if that device needs an authorization.
    Regards
    Ahmed,
    Regards
    Thanks, it worked to only start and stop commands. It dint work for this command
    GET /command/?cmd=start%20time001
    Same command works fine in LUA, Like
    HWS = Net.FHttp("192.168.x.xxx",80)
    HWSReponse = HWS:GET("/command/?cmd=start%20time001")
    any help?
    Ahmed,
    i will check some GET command issues tomorrow on some other device
    Regards
    Can some one help me on this?
    Ahmed,
    GET don't recognize space symbol (%20) and probably ignores it when sending a command (and corrupts it), try omitting it in code. Most devices don't use commands with space, what type of device do You have, can You change those commands manually?
    You can also check if there is a way to send this time parameter with other command.
    Regards
    Ahmed,
    Regards
    Thanks, yes it dint take symbol. I will try to change code.
    On 7/30/2014 at 8:02 PM, murnko said:
    Ahmed,
    Regards
    Hi
    I am in the same boat, but instead of a "device"  I am trying to send HTTP command to IFTTT, so the url is
    How do I make this work. Have tried putting maker.ifttt.com in the IP field. and then created a button with below command
    POST /trigger/home_announcer_start/with/key/{key} HTTP/1.1
    does not work. If I put the url in the browser all is good.
    Can you please assist.
    Regards
    Sammy
