Control Samsung Smart Tv from HCL
Sorry,my english is from google translator.
In case anyone is interested, I'm implementing this solution to control samsung smart tv from HCL, as we await the next century to v4.x, plugins... and spanish interface, etc.
You need a web server, I have no problem in my case because I use mac mini for plex, eyetv, vpn, mail, recording cameras, etc.. and always is on.
You need to publish to a web server php file attached samsungremote.php
In the attached file .zip there are also index.html, exemplary to send commands to the TV, I used it for the first sending the first command to the tv to give authorization in samsung Allshare .
Modifies the data samsungremote.php, ip tv, and the ip web server that will send commands to the tv (no ip HCL), also the mac web server, and change LE46C650 tv for your model (this does not if absolutely necessary, I changed my code tv), also changes if you want to $remotename that you like if you want.
     $ IPTV = "192.168.1.96"; / / IP Address of TV
     $ myip = "192.168.1.200"; / / Does not really seem to be used
     $ mymac = "00-0c-29-3e-b1-4f"; / / Used for the access control / validation, but not after That AFAIK
     $ appstring = "iapp.samsung iphone .."; / / What the iPhone app reports
     $ tvappstring = "iphone.LE46C650.iapp.samsung"; / / Might need changing to match your TV type
     $ remotename = "Samsung Remote for HCL"; / / What gets Reported When it asks for permission / Also shows in General-> Wireless Remote Control menu
When you have tested the tv respond to commands from index.html, creates a virtual device with buttons you want, making calls with this url structure
GET /samsungremote.php?=KEY_POWEROFF HTTP/1.10x0D0x0A0x0D0x0A
Due to time constraints I have not yet created the virtual device, but I am 100% sure it will work because the call to
works and off tv
in samsungremote.php KEY_ is a list of available and here too
unfortunately samsung tv not support power_on.
I wish someone would be useful
4 answers to this question
Looks nice. I was trying to get something like this. I need just a power off function in my virtual device.
will test it tomorrow.
    I've had some time, I've tested, I confirm it works correctly, just a detail, the virtual device must have this structure
    GET /samsungremote.php?key=POWEROFF HTTP/1.1
    host:192.168.1.200:8888
    0x0D0x0A0x0D0x0A
    you can recreate all the buttons for remote controller in the virtual device
    (*) change the ip host: by your web server and port if you have not published on port 80
    hmm. not working.
    You mean The host is your fibaro? What port on TV do I have to use?
    Probably I missunderstood you. You run your php script on a server, right?
    works perfectly,
    have to publish on a web server (with php) index.html and samsungremote.php
    edit samsungremote.php and change the values ​​with your data as i write in the first post
    remember
    $ Myip = "192.168.1.200"; / / Does not really seem to be used
    this is the IP of the web server, NOT Fibaro, tv allows connection to the web server, from the virtual device that is done is to send the url to the web server and the web server makes the connection with the TV.
    and
    $ Mymac = "00-0c-29-3e-b1-4f"; / / Used for the access control / validation, but not after That AFAIK
    type here your web server MAC
    go to
    server / index.html, you will see a web remote controller, uses a push button to make the call to confirm on television and television connection.
    then creates the virtual device as I put in my second post.
    I assure you it works.
    tv port is 55000, is already indicated in samsungremote.php
