Has anyone managed to wire a flood sensor probe as per the advertising photos ? If so where did you get it. The only thing I can see is that short of cutting the probe of the everspring flood sensor and using that, where else can you get these
No response from Fibaro when asked via twitter and facebook.
fergalmccarthy, you can use any two wires connected to Sens1 and Sens2 ports.
How about this:
From UK but ships to Europe
How about this:
I use these
/emoticons/default_icon_smile.gif" alt=":-)" /> work well!
    Thanks guys, will look a bit better than two ends of wire running down the wall.
