Fibaro Motion Sensor Value Settings error
Guest Axel
Tried to set Parameter 40 ( ILLUMINATION REPORT THRESHOLD) to 100.
Get "100undefined" after saving.
Axel,
Try re-adding module or reconfigure it.
Regards
Guest Axel
    Doesn't help.
    Anybody else using the sensor working with 3.591Beta and tried to set values ?
    I think it is a problem of the Software.
    Axel,
    Where exactly message "100undefined" appears?
    Regards
    Guest Axel
    Please look at Attachment...
    Had the same with a Qubino shutter today, but after saving a few times the error was gone and the values were saved.
    Axel, boerremk, don't worry that is only a small problem in js where he want show unit but for value there is no unit
    Guest Axel
    But I can't set the value ! Do you fix it ?
    When you change a parameter value click save button, then wake up the device.
    After data exchange refresh web page - after that new values will be visible.
