I have the Fibaro system now for a year and have a lot of scenes. The problem I have right now is that a variable is changing, but I don't known witch scene is doing this. In the eventpanel I can't see what scene does this, is there a trick where I can see this? Or how can I write my scenes better? I am already using fibaro:debug to trace everything, but this I can't see at the moment. I have no documentation of my scenes, so I will start with that.
Any ideas?
I use a virtual device to search al my scenes for code (see attachement, found the code somewhere on the forum, also added the picture I use for the device).
You have to fill in the username/password for your HC2 and the ip address and port.
You have to fill in the pattern you want to find.
It will send you a mail with the scenes with the pattern you want to find.
Hope it will help you!
    boerremk,
    Thanks, that was the trick
