palomaray 5
Hi All,
I have some dimmers and various outside lights etc. that I want to set to run via a scene, but I want to just switch the scene on, not necessarily by a separate switch, but just by a toggle or similar on the HC2.
I don't know any LUA, so wondered if there is a way to do this with blocks?
Basically I want a simple scene called "relaxed evening" or similar, which when triggered will turn on 4 lamps at 50% and turn on some outside lights (LED so on full). The lamps are all separate and work independently of each other, so I don't want an association that makes them all come on if one is operated.
Any help would be appreciated.
Many thanks.
Ray.
5 answers to this question
