relay switch 2x1.5kW
Guest nohed
have a problem with my relay switch 2x1.5kW sometimes so after an hour it will start to turn on and turn off all the time until you turn off the switch.
is this heating problems in the plug?
nohed, make sure it is not reaction to alarm frame, if you do not want this device to react on alarm frames, please set parameter 30 and a couple of following to "Device doesn´t respond to alarms"
Guest nohed
    okay now I've done it so now I get to see if it comes back
