Fibaro Event Panel data to a MySQL Database
I really don't like the eventpanel of the Fibaro interface. It's slow and unable to get good statistics.
I want to store this data into an own database to get statistics and show information about my system to other users. Has somebody already created a php or other solution to get the data into a database? I have seen the Excel macro, but I want to have a direct input.
thanks
5 answers to this question
thanks
One possibility is to root the HC2 and get direct access to the MySQL database that Fibaro already stores the information in and have your "php or other solution" connect to fibaro's mysql database to retrieve the latest info.
Lockzi, hc2 don't use mysql :]
and what about using api?
last y events (example for 30 records)
records from x time to y time (x and y in timestamp)
when you got php you only download json and you working on it
I built a script which does what you want - but you should be aware that it puts quite a bit of strain on your system. Especially as event log handling seems quite labor intensive on the HC2.
But it is quite simple to set up a script which will request the last hours events and then input it into a MySQL database for handling afterwards. If you are using a linux box as your server, you just set up a CRON job which runs hourly and then forward the last hours data to the database.
I can see if I have the script somewhere - unfortunately it got lost in a server crash, and that particular script (along with the entire MySQL database) was not part of my backup
/emoticons/default_icon_redface.gif" alt=":oops:" />
Otherwise, just create a php script something like this:
Very simple code and some good tutorials available on the web in case your php'sk isn't too strong. But I'll just check if I should have the script lying around somewhere.
    Dalle1985,
    I am not a programmer, so if you have the example
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I am running a synology, so I can run php
    remcoploeg - did you get the script? Im interested in making something for my Synology NAS aswell :)
    Event Panel sucks - tbh!
