Fibaro Motion Sensor Brightness Update
Guest Axel
I want to use the Lux from the Motion Sensor to switch light.
But the Values are not updated, Always 10K.
Guest M.Grajczak
    Try to reduce value of parameter 40 in Motion Sensor's advanced settings.
    It determines the change in light intensity level resulting in illumination report being sent to the main controller.
    Remember to wake up the device to send new configuration.
    Change:
    40 to 200
    42 to 1800 or 2700
    That will work fine.
    HTH, Dave
    deleted
