Dear All,
Please advise if you have any successful experience in compatibility of HC2/HCL with any z-wave door locks?
Tanx
They will be integrated in next update, for now it is possible to use them with alpha version.
j.nowacki, Yake lock isn't working with last alpha (3.904).
My Yale lock was working (basic lock/unlock) with last alpha, but not now. I tried to re-include device (very close to hc2), but it was unsuccessful.
giliardi, are you using the yale zwave lock? Cool, any pictures or configurations you can share? Yale zwave lock has been just introduced in Singapore and I can't wait to see it.
Unless you are talking about todays alpha 3.906 which I haven't installed yet ? because the last alpha 3.904 broke support for the yale locks.
EDIT :
in 3.906a Yale Door locks are fixed and functional as they were before 3.904 YEY !
Better than that we now get a status change when manually locked or unlocked too, and remote is working, and scene integration is also working.
I had to remove and re add, not just re configure. And it takes forever to finish its association/configuration..I just let it keep going till it was done.
Battery level reporting is still a bit dubious with brand new batteries it still flashes low battery. Doh !
EDIT2 :
Battery levels working perfectly too. I just had to wait for a 12 hour period for the system to do whatever it does, and now no more false battery level reporting ! (yey)
cheers,
al.
  • 2 years later...
" to "
Temat został przeniesiony z "
" do "
