Cant restore backup
I installed the alpha 3.904 but to many devices where shown as dead nodes so i wanted to go back to 3.591 but after i have done a full recovery back to 1.038 i could only install backup up to 1.047.Cant upgrade no force update or anything and if i go back to recovery i can only recover back to 1.038.
When trying to install a 3.xxx backup i get error 4.
How can i install my backups that is 3.xxx?
Thanks for all help
Jonas
I had the exact same issue, Fibaro support had to connect remotely to correct it.
Did you try to backup from 3.904 or did you use recovery procedure? Personally I tried to backup and I think that this cause the big mess.
    Ok.
    No i did a recovery.
    But cant get any further than 1.047.
    If you made recovery and cannot perform updates for the last version you have backup for, please contact support: [email protected]
