Andrew 0
Hi Everyone,
I have a real problem with my TKB Wall Plugs.
They were connected to a Fibaro HC2 which died (unit could not power on) and I am having a real problem trying to get the TKBs to work with the new (replacement) Fibaro HC2 because they're already associated with the older system.
Does anyone know how I can get these to work on the new system? I've tried to make the Fibaro forget everything on the z-wave chip but the problem must be with the TKB plug chip remembering the old HC2.
I can't find a reset button on the plugs.
Thanks,
Andrew
Hi Everyone,
I've solved my problem. I found the manual here:
and reset the device with three clicks on the front button.
Thanks,
Andrew
