motion sensor (FGMS001)
Guest nohed
what's the problem with the motion sensor then locks into position breached in an entire day ????
More information please? And there are already some threads discussing about this issue. You should look up those thread before asking what's the problem with your motion sensor.
Perhaps you can provide more information like your HC version, Paramter 1 value of your motion sensor and so on.
  • 3 months later...
idem, with HCLite
Probably been knocked or seismic or tampered... you can try to change a parameter 20 to 0 then check again for a few days
It is caused by a overload network - which is the main reason we need V4.
The software for the network is weak and can't handle a few sensors reporting values at the same time. Since I reduced the multi sensor to motion only they work pretty well but you get a single sensor for the price of a multi sensor.
/emoticons/default_icon_neutral.gif" alt=":-|" />
