Hi all,
i've realized a script how prevent blackout in the house (over power consum), the script works well ...if power load is > than 3000w i find max load in wallplugs and power off biggest load.
...i've a question:
-How is the better trigger method to lauch script?
now i use aeon energy meter (main clamps read value with 5% of tollerance) and trigger over 3000W....but energy meter seems slow than wallplug....
is better if i use luascript for calculate reltime load from single plug by simple sum?is heavy calc for fibaro HC2 (10 wallplug)?
/emoticons/default_icon_eek.gif" alt=":shock:" />
is possible to read live energy load of the rooms directy from energy panel fibaro? if yes i can use that like a value trigger...
fibaro...what is better?
/emoticons/default_icon_question.gif" alt=":?:" />
Current energy drain in single room can be found here: IP/api/energy/now-3600/now/summary-graph/rooms/power/RoomID
It contains time-stamp for GMT zone and power use. You can trigger your scene with that information.
