Today, one of my FIBARO DIMMER has stopped working. Suddenly.
It appears as dead in the HC2, but it doesn't respond to wake up.
I've also tested delete, and add... but once deleted, I'll never add it again because it does´t respond.
It's powered, but I'm not able to add it again. Is there anything I could test? any new firmware or whatever?
Thanks a lot in advanced
You sure it's powered? Try using manual switch to on off the light?
I had the same problem, i just changed the lightbulb and it worked again.
It was dead in gui and didnt anwer on wake up
Do you try to re-add device in direct range of controller? Please reset dimmer as described in manual and try to include it again.
