[Virtual Device] Glabol Caché iTach Wifi2IR Checker
Hi to you all!
I'm still learning LUA-code and the best way to learn is to just do it !! So, I made this Virtual Device to check my Global Caché iTach Flex WiFi to IR device.
Preparations:
Add a Global Variable 'VD_iTach_Instance' to your HC2 system and download the attached Virtual Device.
Insert the right IP-address and TCP-port (normally 4998) in this Virtual Device
With this Virtual Device you can check some iTach system functions:
Online or offline (TCP),
Which files are stored on the device (HTTP),
Test iLearn function (HTTP),
Test iLearn function (TCP).
The HTTP-iiLearn function is still a bit buggy but I will try to improve this in the near future.
To see more what is happening between the communication and the HC2 you can open the debugwindow of every button. This shows some additional information.
I also made some icons for the Virtual Device which is added as attachments.
Special thanx to:
-- Krikroff (LUA-code snippet reporting Filenames)
-- and all others on Fibaro-forum who shared their knowledge which I have gratefully used!
Have fun and remember to post comments so you and me can learn from it!
