i made an script it detect is the window open or close and then, depending on the state, save the value to a global variable or send it to the thermostat. You can swing the window/door....open....close....open...close or somehow otherwise, the script detect the actually status and when the status is the same does it nothing.
Background of this script: Children and they swing the window back and forth or the terraces door..... open...close...go inside... outside....etc. Is the door open or close for ca 60 sec then change the script the value of the thermostat or not.
And this is my first step to create my own heating panel
But actually try to learn lua and look how it works
Would be nice if you check the script and give me a feedback how it finds.
Sorry for my very good English
regards Alex
At the moment it works with only 1x window/door sensor and 1x Thermostat.
To use: You must create a global variable, with any name, and change this name in the user settings and change the IDs of the sensors.
