chatting 1
I have the following problems after the upgrade
1. When delete device, action will not cease at set 30 seconds, it will run in indefinite loop. You cannot stop it unless by unplug the HC2 power cable.
2. When re-configure device, it will give a new ID and act like newly added device
3. All LED when re-configure, will turned into another Z-Wave device which cannot be re-configure back as LED device
4. Sometimes LED devices will be disappeared after re-configure
5. Fibaro plug no longer display the colour spectrum showing power consumption
6. LED shown on the webpage interface all as "turned on" whilst start up or refresh page, but actually all LEDs are in off state.
7. You cannot test the 'transfer ok' by click the off button when the device is really off. (please put this back for easy testing the connection of nodes in the network.
8. You cannot control turning on/off LED switches by iOS Fibaro apps.
