chatting 1
This is the wakeup scene I learned from here.
%% properties
%% autostart
%% globals
local TotalDevices = 3000
while true do
local i = 1
local anydead = 0
while i < TotalDevices do
local status = fibaro:getValue(i, 'dead');
local name = fibaro:getName(i);
if status >= "1" then
fibaro:debug(i..' dead '..name);
fibaro:call(1, "wakeUpDeadDevice", i)
fibaro:sleep(5000)
if status >= "1"
then anydead = 1; fibaro:debug('Really Dead')
else fibaro:debug('Jest OK '..name)
i = i + 1
if anydead == 0
then fibaro:debug('There is no dead devices')
else fibaro:call(1, 'wakeUpAllDevices')
fibaro:call(2, 'sendEmail', 'Device dead , really', '..')
fibaro:debug('Wakeing up')
if fibaro:countScenes() > 1 then fibaro:abort() end
fibaro:sleep(60*60000)
After the upgrade to 3.907, it's not working saying that line 16 has error. According to Fibaro, "There is some problem with reading: local status = fibaro:getValue(i, ‘dead’);
if status >= “1” then should be == now;
mind that ‘dead’ gives values true and false now, not 1 or 0"
What to change to make it working?
7 answers to this question
