UK - Rollerbinds that can work with Fibaro RollerShutter Mod
Guest andyhud
Hi Guys
Just wondering if any UK/Europe folk know of a company (or a method you have used) to get some rollerblinds that support the Fibaro RollerShutter module? More specifically where it can sense how much the blind is up/down?
I need to get some for my windows but want to ensure I source the right ones.
Kind Regards
Andy
All roller binds with 230V AC engine and limit switches should work properly. Notice, that Roller Shutter 1 need mechanical limit switches, while Roller Shutter 2 works with both mechanical and electronic ones.
Guest andyhud
    Many thanks!
    How do I know if the module I have is Version 1 or Version 2?
    The modules I have are FGR221 and the manual says Version 1.4-v1.7
    Cheers
    Andy
    andyhud, FGR221 is Rollers Shutter 1. It does not have support for venetian blinds, power metering function and does not work with blinds with electronic limit-switches. Also it is not able to test Z-wave range. If you need any of these functions you should get FGRM222 which have them implemented.
    Guest andyhud
    Ok cool. Many thanks for confirming.
    Andy
