How to get the complete history of a device with API
Dear All,
I have a jacuzzi heater which is overheating and in consequence, melt the plastic case around him so bad that the water is leaking through it
To prevent this, I use the flood sensor which:
1. Detect flood with extension cable
2. Measure temperature directly in the plastic case.
If higher than 45° => report mail and cut the heater.
Well, again it overheated, the plastic melted and the flood sensor too.
On the event, I can check 1 week from now and it never went over 40°C (It melted so it must have been higher than 40°C)
Does somebody know how to get the whole log of this flood sensor because the event is not a very easy way to check 2 weeks of T°. It only allows 2 days to be displayed...
Thank you very much in advance!!!
7 answers to this question
you can check it by using that http command
example is from 25.8 till today
Is this possible per device?
Aahhh thanks! I have been looking for this for a whole evening
ehm, per device id: just add:
&deviceID=477
thanx!
How do I use a get in a scene? I though this was implemented in scenes from 3.90x right?
With:
HC2 = Net.FHttp("127.0.0.1", 11111);
I get an error that Net is Nill.
stevenvd, wait for new official api manual - it will be soon released
    Thank you very much Andrew!
    I don't understand, I still don't see any temperature above 40°C (action was at 45°C). How could it miss a temperature increasing so high that it melted the plastic case of the Flood sensor? For sure this High temp must have last a few minutes...
    Any idea?
    [ Added: 2014-09-09, 15:21 ]
    Could somebody tell me how to decode the "timestamp", sorry but I still don't get how 25/08 = 1408935660
    [ Added: 2014-10-21, 10:34 ]
    Dear All,
    Back with this unanswered question:
