Hello guys
i am using HC2 in my office. I want to make my office more Fibaro and Smarter.
I want to get rid of the time attendance machine we have.
Lets say, if I come in, I touch the iPad and type my code (my room can be Arm) to disarm my room and will register my name in History that I have Disarmed my room. At this time lights will be ON in my room and AC is ON lets say.
When I go out I can re Arm my room and my room will be off and it will be registered that I left at 6 PM for example
What about another thing, I want to add Virtual devices, a virtual device for each user. So for example, from my office, i can press on "COFFEE +" to order 1 coffee from the office boy.
At the office boy's iPad he will get a notification and he has his own virtual device's label which says:
"Coffee - 1 - Room#1"
What do you think? Will it work?
Anyone can help me coding this thing?
Do it easier, just let the vd send an e-mail to the coffee boy with the description of the room and # of coffees
    Email will take time
    The office boy Fibaro user will have only the Virtual Device
    I would yell at him.
    Advantages :
    - Fast reaction (the speed of sound is 343 metres per second (1,125 ft/s))
    - Priority Management ( those who yell the hardest , or bosses get served first ( completely automatic)
    - eco friendly ( doesn't need power)
    - Reliability ( doesn't work if coffee boy is ill , or your voice is off)
    Disadvantages
    - Noise
    ;D
    How about if it like 400 m2 office!
    Yelling would be a PROBLEM
    And we claim that we sell "Smart Home Solutions" to our customers
    ;D
    NOT A PROBLEM:
    YOu have to do quite some work to get what you want. First off, if you want to have a arm/disarm solution you need to build an alarm front end with something inbetween the fibaro and your input panel. I built something similar for my home tablet interface. It was a pin panel where you could input a user and then activate using their own PIN code. depending on who disarmed the alarm, it would have different actions. Once you have the pinpanel setup, it is just a question of setting up a scene which activates when a certain pin is entered.
    The coffee ordering system is somewhat easier. You just create a virtual device where you can choose how many you want of a certain thing (i.e. coffee) and a set of buttons for what you want (coffee, water etc.) and then the VD will send the order to your office boy as a push notification. But again, I'd opt for a custom interface for the system, where you can choose whatever you want on a screen and then whenever you push a certain order, it will automatically be pushed to your clerk.
    HAHAHAHAHA!!!
    I like your solution
    What i mean is that using the same iPad as the time machine attendance!
    One on the entrance
    How far can I go with Fibaro?
    • 1 month later...
    For office attendance and for coffee order the best suitable ones are electronic devices than that of human work force.
