Netatmo Plugin 4.017Beta
I've got the plugin kinda working, but not at all ..
I've worked out to go to dev.netatmo.com and started an app.
I've got my secret number and auth name, all good ..
but when i click get devices, i don't actually get anything ?
my Netatmo web tells me it is good to go, the HC2 tells me it is connected .. but clicking get devices still does nothing ?
Can anyone point me to what i am missing ??
Is there a step I've mucked up ?
Cheers,
al.
  • Answers 60
  • Created
  • Last Reply
Guest shapa
They could not make a simple http api calls working
Just to compare: Indigo 6 netatmo:
    Sure, but think how cool it will be when all these talented forum dwellers get into dev.fibaro and start making some plugins
    I can't wait !
    Cheers,
    al.
    PS, that does look pretty sweet though!
    Guest shapa
    They launched dev.fibaro service and (as usual) it's not working properly at all.
    Just to note
    Try to register or do something.
    Trust me, for 2 years there was a lot of promises, finally we've got extremely unreliable / buggy software. May be in 3-4 years it will be better.
    I'll better go another way with something which works right now.
    Hi, is The Satel Integra integration ok with this BETA? any experience yet?
    Will the ID 's stay the same for LUA Scenes ?
    alandee, can you check in unassigned room do you got them there?
    like
    shapa, indeed at the beginning too big traffic caused some problems but now everything work fine. But if you are still having any troubles with entering developer.fibaro.com please share them with us and we will be happy to assist you.
    Any chance of a step by step please, seems to be missing a few pieces from creating app in netatmo to connecting to fibaro
    A.Socha,
    is nest smoke working with this plugin?
    if no, why not??
    Hi Fergal,
    I got called into work, so I can't show pics, but did you go to
    ? It's not an intuitive step, but some "investigative googling" and blind luck helped me stumble across it
    If not .. basically you sign up there, add a new app, fill in the required stuff, i just made up a name, then you get the secret and other key to fill in on the hc2 Advanced screen.
    Then save, then click get devices .. and it will tell you eventually that it is connected. It's actually more straightforward than it sounds. It also gives you access to all the api info at dev.netatmo.com.
    Then when you look at your netatmo app you have the fibaro app name you made up showing in Settings/My third Party Apps on your phone as well.
    Hope that helps.
    @Andrew :
    I'll have a look once I get home this afternoon and report back. I did not check there, so fingers crossed they are !. Oh and that is way cool if it comes up like your screen clip!
    Cheers,
    al.
    Alan thanks for that, thats what I did alright, thought i'd missed some magic step but don't get any devices. I've filled in all the fields but it doesn't connect. Just get not connected in the plugin.
    Ahh, yeah OK, so go back to netatmo dev and reset the keys and then use them. it didn't work with the first generated keys when i did it last night, but happened almost straight away when i copied and pasted the second set.
    Mind you .. I don't know if being connected means I've got it working yet till I get home...
    Cheers,
    al.
    [ Added: 2014-09-12, 11:09 ]
    A.Socha, Nope.
    They are there but hidden hidden ?? It says 4 devices in unassigned, but shows nothing ?
    Image attached.
    [ Added: 2014-09-12, 11:15 ]
    A.Socha, When I click Get devices in the plugin, nothing happens ( or nothing appears to happen ? )
    I'm almost confident it is something to do with the get devices button ?
    ta,
    al.
    like
    My unassigned room is full of zeros. Main netatmo plugin shows that it is connected.
    almj, Hi, do you have 4 or 8 items in unassigned with zero's ??
    Thanks,
    al.
    I have 8 including main plugin device
    Thanks Alan, i removed the device in HC, regenerated the keys and added it back and now i'm connected but not seeing any data / devices bar the netatmo one i created.
    A.Socha / almj,, In the dev.netatmo.com should the following stay as they default ?
    Request token URL
    Authorize URL
    Callback URL None
    That is all I can see that can change ?
    Thanks,
    al.
    Guest cobaltjeh
    Same problem here, plugin says that it's connected, but the button to get devices isn't doing anything.
    alandee, yes, checked everything.
    Same problem for me,
    I use it for a long time and everything is set correctly
    1. install plugin on HC2
    2. go to
    and login with your data
    3. create new "app"
    4. clik on that app you will find there
    Client id
    Client secret
    5. go back to hc2 and chose add plugin
    6. go to adv tab and fill all inputs
    Username - your login for example [email protected]
    Password - your password
    Clinet ID - from app what you created
    Client secret - from app what you created
    7. save
    Check on you account setting on site
    is in 3rd part plugins are info about your app if yes then after while it should show status connect on HC2
    If it will be after 5minutes still empty try restart hc2 and check again when it will show go to next step
    now you can press button "Get Devices"
    as result you should saw something like that
