Lambik 192
For those who have an iKettle and use the LUA-code from
, I made an additional LUA-code.The reasons:
- Because I have a Fibaro wallsocket switch in the main power (for disconnecting the main power from the iKettle when I'm not at home and measuring power consumption), the status in the original VD is not updated anymore after disconnecting/reconnecting main power.
- When the iKettle is manually/locally operated the icons are not updated.
How?
Add the custom code in the original main loop code (starting at line 29) and change your icon id's depending your own icon id's:
Have fun!
10 answers to this question
