Hello guys
I can tell that sometimes using Dimmer with LEDs may cause some problems.
I have this type of LED
(20 w/m)
Do you recommend using Fibaro Universal Dimmer?
Can i add a device so i would be able to use this LED strip?
Smartelite, this document says, that power supply is not included, have you considered using RGBW module instead of transformer controller by the dimmer?
    You mean not using a Dimmer, but using an RGBW?
    Yes, led strips can be supplied with 24V, which means it can be used with RGBW module.
    Is there any considerations before connecting RGBW with LED dimmable lights?
    I will use RGBW Controller to control 4 LED circuits (60 Watt each)
    Will this work perfectly?
    Smartelite, please make clear what kind of lights you want to operate: from the first post it looks like you want to use led strip now you mention dimmable led lights. Do you still mean led strips?
    Yes, the same LED actually. They are dimmable strips LED lights
    I am talking about Dimmable White LED strips
    All maximum ratings are available in manual. At 24V DC supply the module can sink 288W from all 4 channels. If you are not sure about electrical connections please contact electrician or other qualified person.
    I know how to connect them. My question is, you know, using Universal Dimmer with LEDs lights make issues sometimes. Will i suffer from the same issues?
    Smartelite, as you said, you are using RGBW controller not Dimmer. RGBW is dedicated for use with LED strips.
    Ok then thank you
    Just wanted to make sure
    I will write my review after the installation
    Thanx
