Tibus31 0
Dear All,
I would like to change a parameter of a ZXT-120 using JSON in order to recall manually learned IR code.
I've found a code on another forum (Thanks Krikroff) and I did adapt it to my need (I'm a newbie with JSON).
It returns a 400 HTTP status code (bad request).
Here is the code:
local json = '{"id":110,"properties":{"parameters":[{"id":34,"size":1,"value":2}]}}'
local HC2 = Net.FHttp("xxxxx", 80);
HC2:setBasicAuthentication("admin", "xxxxx");
local response, status, errorCode = HC2:PUT("/api/devices?id="..deviceID, json)
if tonumber(status) == 200 then
fibaro:debug("ok");
else
fibaro:debug("err ID: "..deviceID.. " status: "..status);
IF i test the body (see attachment) in the new "API ACTIVE Doc" section, it works, return a 200 status number and my ZXT-120 recall a manually recorded code and turn ON my AC!
Could somebody help to correct it?
