Outputing the contents of a table.
If you have a table (maybe decoded from a json string using
)... for example:
and you want to output its contents to the debug area, you may be tempted to try:
And you would probably be disappointed to see something like:
So here are two functions which work together to produce something a bit nicer.
Use the function like this:
And now you will get output like this:
Please note that tables in Lua are not ordered (unless the elements are numbered 1, 2, 3, etc) so each time the scene is run you may get a different output order, but the essential content is the same.
Happy Automating!
Adam Bewsher
dear Adam,
i tried to save a table in a Var, but no success so far.
can you
