Tibus31 0
Dear all,
I have big issues when trying to set the flood sensor on PSU.
When placed on 12VDC, it doesn't work, I hear a beep like a smoke sensor not included. Also, it doesn't react when sense1&2 are shortcuted.
But if I just disconnect the 12VDC (running then on battery), it works perfectly fine.
Also, the little gold pins show 13VAC on it. Without flood sensor connected, the PSU output shows only a small 4VAC.
The PSU is also powering a universal sensor which always worked fine.
I changed the PSU to try but same thing.
Anybody experienced the same issue???
11 answers to this question
