FIBARO AND VITRUM SWITCH ASSOCIATCION ZWAVE
Guest Paweł Świerczyński
Short presentation of the association 6 channel on / off switch with FIBARO.
The switch allows for association 6 different light sources.( turn on-turn off function)
More Information:
www.fibarokrakow.com
[email protected]
Site has been down on few times I tried.
More Information:
[email protected]
Looks good, but does this only works with on/off. What about dimming?
    we waitting for dimmer and battery zwave switch when we test show how its works
    Nice
    does it fit in a single electrabox in the wall and wat is the depth of it
    Kagle i suppose to think is little bigger than standard wall-hole
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />, back has no oval shape but square. But i think its not very important becouse you can little hobnail a wall to instal switch.
