Ideas for HC2 developement
Hello together,
currently we're testing your HC2 with latest beta and as i can see, we're missing some functionality (as of my experience as web-platform developer and erp-software developer since 19 years) i would expect following from a HC2 version in future:
* Access to Systemlog somewhere, currently i can see latest log on top / middle but not everything in this small box
* Access do debug-messages from different scenes / plugins in a central place. That means its simplier to see problems
* We had problems with i.e. our NightTime scene. Sometimes the scene stops working ... its active but is not running in background. After manual start, it runs some hours / days and stops after that without any errors. I think there should be a background-job, which checks i.e. once per hour / once per day if the active scenes are running!
* The more we're working with HC2 and LUA the more its getting interesting to us.
The more scripts / scenes / plugins we have the more the system will get busy. To make the system better in this case, you should add a "priority" flag to all scripts. i.e. "realtime", "high", "normal", "background". That means you can i.e. save a "queue timestamp" for all scripts, sort for the same second and run all realtime, then all high tasks and so on or you can define any other priority thing. Enabling such a option would also help i.e. with a lot of danfoss (max 20 current)
Is there any place like bugzilla where we can add suggestions / ideas for future HC2 ?
Brgds,
4 answers to this question
Great ideas!
Have a look at here
    Great ideas!
    Have a look at here
    Is that website checked by fibaro?
    yuzo, we try to monitor forum as well as other sites when developing our system, to match customers expectations.
    Thanks a lot for your work!
