Smoke sensor temperature for heating?
Hi.
I'm running 3.590, and can't use smoke sensor temperature as a sensor for heating panel.
Is it possible i newer versions to use the smoke sensor temperature sensor as a sensor, and combine it with a relay controlling a heatsource?
eg1l, smoke sensor temperature is visible as separate device since latest beta version, it will be also available as such in future releases.
    Excellent, thank you
